help me identify if this is a ls6 cam
Old Aug 25, 2012 | 09:34 AM
lavoy's Avatar
Default help me identify if this is a ls6 cam
i bought a cam to replace my ruined ls6 cam and it arrived today, its slightly used and when comparing it to my old zo6 cam the stamp is different on the end of the cam, mine actually has a long part number and 3 rows of numbers, this new cam simply has stamped, not printed or etched but stamped into the end of it 5308 i know the ls6 part number ends in 5308 but never heard of that being the only number on the cam. and never saw one stamped into the metal like a crude old fashioned die stamp.
Old Aug 25, 2012 | 03:31 PM
chrisfrost's Avatar
Have You measured the lobes ,,,,,,,,,,first the base circle ,,,,,then the lobe ,,,,,,then subtract the base circle from the lobe ,,,,then multiply by 1.7 unless You have different ratio rockers .
