cam and spring question
Old Aug 26, 2012 | 04:02 PM
bp m1009's Avatar
i might order those too now lol. thats a great price for springs retainers locators and seals!
Old Aug 26, 2012 | 04:52 PM
PREDATOR-Z's Avatar
In single beehives I've used Comp 918s, Pac 1518 with no failures. The longest lasting on high lift (without significant loss in pressures after 15k) has been PSI 1511. I tend to use those nowadays if I'm able to locate them easily.
Beehives have attributes that are not available in duals, some of which:
- Better harmonic control
- Lighter effective moving mass weight.
Old Aug 26, 2012 | 05:26 PM
chevybayboy's Avatar
Ok im either goin to roll with PAC 1518 or brains from tick ill do some more researching before I decide
Old Aug 26, 2012 | 06:39 PM
willyfastz's Avatar
Restricted User
Originally Posted by chevybayboy
would I have to shim the 1519
The last set I did I didn't have to shim them. But I did check them to see what the install height was. Seems like they came in at around 1.750" and they where on a souped up .615" lift cam.
Old Aug 26, 2012 | 06:42 PM
willyfastz's Avatar
Restricted User
No worries I still dont know if im going to go with PAC or comps so it might be a month or 2 before I Start my rebuild thread
The Comp 918's used to be really good when PAC was making them for Comp.
Old Aug 26, 2012 | 06:44 PM
willyfastz's Avatar
Restricted User
Look at the application as well as price. Predator-Z has given you some good info.
Old Aug 26, 2012 | 06:59 PM
Yea I def know I was leaning more towards the PAC 1518 the duals just comes in a set with reasonable price but since im waiting anyway I might just get PAC1518 and buy retainers and seats
Old Aug 26, 2012 | 07:04 PM
willyfastz's Avatar
Restricted User
To help with price you can use the stock retainers and seats with the 1519's.
Old Aug 26, 2012 | 07:22 PM
Ok cool do the duals have an advantage over the singles? If there rated the same?
Old Aug 26, 2012 | 09:29 PM
Sales@Tick's Avatar
Thats for the kit? I think ill order thoses wen I order my springs
That is for the entire kit and caboodle.
