383 troubles
..trouble is the first tuner had put the car so rich, that it actually glazed the cylinder walls, so I guess the rings havent seated properly and now I have blow-by..car eats about 1 litre oil every 100k if I drive it hard. The car has since been retuned, as best it can be considering.
couple questions..
bought the car to the track anyway, best run was a 12.4@116mph ...not what I wanted, besides the burning oil, is it possible the car is losing compression?..resulting in lower times(less power). The feels strong all the same.
This is a street car, that will maybe see the track 3 to 4 times a year, and when I re-ring the car in a few months, should I lower the compression?
I cant remember the actual rings used in the car other than they weisco (weisco forged pistions)...is it possible to use a softer ring?, if that makes sense...In the beginning I was planning on using a 150 to max 200 shot someday, but just want to get the engine running correct now before thnking about power adders.
I could way off, maybe wishful thinking.
