Cam and heads
Old Sep 3, 2012 | 09:05 PM
gbrett's Avatar
Default Cam and heads
I have a 2000 ls1 with ls6 intake long tubes and true duals the engine is in a 1991 Firebird it has no cats and all emisions devices are removed. I am thinking of going with the gmpp 88958665 cnc'ed heads I am having trouble deciding on a cam. The car is a weekend driver and road corse and auto cross occasional drag strip. Right now I am happy with the 6200 rev limit so I want to gain below that limit. I am open to others heads as well the car weighs 3200 lbs has 3.41 gears and a M6. I am willing to spend the dollars for the best combo so give me some oppinions please.
Old Sep 3, 2012 | 09:45 PM
garygnu's Avatar
look at air flow research heads,or trick flow heads,or Texas Speed PRC heads.get a fast intake.you can get a cam from Patrick -G.vengeance racing ,and Texas Speed sell good head/cam combos.
Old Sep 3, 2012 | 09:48 PM
Mike Morris's Avatar
Give AI a call and have them grind you a custom one.
Old Sep 4, 2012 | 11:12 PM
1nasty86's Avatar
Turd Gen Guy
just 6200 rpm? wow... i wouldnt be afraid to turn a stock ls1 6600.. as for heads the best " bang for your buck is a set of ported 243's" imo...
Old Sep 5, 2012 | 05:56 PM
garygnu's Avatar
you need power under the curve give Geoff Skinner or Pat-G a call.do you have to run gm heads ,or can you use after market head ?
