Got a problem (ls1)
Old Sep 14, 2012 | 05:40 AM
Tomazzz's Avatar
Default Got a problem (ls1)
I there my name is tomas and i live in iceland.
I just bought this camaro with bad motor
This is how it fyrst died
After this it got new block freash bearing new oil pump
after few mile it died again
Old Sep 14, 2012 | 06:06 AM
bww3588's Avatar
Are you using chamfered bearings for the raised fillet of the aftermarket crank? Also, try using half groove bearings instead of 3/4.
Old Sep 14, 2012 | 06:08 AM
Tomazzz's Avatar
i realy don´t know what bearing are in the motor right now , but i will take good pic of the tear down
Old Sep 14, 2012 | 07:21 AM
mark21742's Avatar
I'd check the crank to be sure it was all in spec and not slightly bent or out of round, and tear the block all the way down and have it cooked, cleaned and inspected for any damage or blockage in the oil passages...
Old Sep 14, 2012 | 08:02 AM
bww3588's Avatar
Fresh crank meaning new crank? Or turned crank? If it has been turned, are you using the correct undersized bearings?
