Changing oilpan
Old Sep 17, 2012 | 06:41 PM
pacamaroman's Avatar
Default Changing oilpan
I just purchased an LS1 longblock from a fellow member. The gentleman I purchased the motor from kept the original Fbody oil pan. I ordered and just received my Fbody oilpan and I'm wanting to install it and I want to avoid any oil leaks. Here's my question: Can I just bolt it down with the gasket and put a little sealant at the corners? Or would I need to loosen the front or rear cover and reseal? I sat the oilpan on the motor and the bolt holes line up perfectly and it sits nice and level. Thanks in advance for everyone's help!!
Old Sep 17, 2012 | 06:55 PM
JaYZeig's Avatar
this is what i did when i built my engine..
like you said, sealant on the corners, where theres
seams, bolt the pan on. i havent had any problems.
Old Sep 17, 2012 | 07:01 PM
Awesome!! Thanks for your response. I was worried that I needed to loosen the front and rear covers to "align" the oil pan correctly. Thanks JaYZeig!
Old Sep 17, 2012 | 07:04 PM
crainholio's Avatar
The front and rear seal carriers will remain aligned during the pan swap, just don't loosen them.
Old Sep 17, 2012 | 07:09 PM
Thanks Crainholio!! I see you have an 82 Z28 with an LS. This engine is for my 83 Z28.
Old Sep 17, 2012 | 07:10 PM
crainholio's Avatar
You'll fall in love w/ the car all over again after the LS swap.
Old Sep 17, 2012 | 07:19 PM
I can't wait!! I grew up driving a thirdgen and always had at least one for a span of over 11 years. Then I got into the fourthgens which I like, but I've always been a thirdgenner at heart. I'm excited about having the nastalgic look of the thirdgen with the power and economy of the LS!!
