Cam and 347cid
Old Apr 7, 2004 | 09:54 PM
Randy WS6's Avatar
Default Cam and 347cid
I'm building a forged 347 and i bought a comp cam it a 595/600-232/236-110 will i have any problems with piston to valve clearence .i have Diamond pistons with 2cc valve releafs and 5.3 heads with 2.02 intake valves shaved .030" i have the comp 918 valve springs right now will the 918's work with that cam or would i need the duel Crains
Thanks, Randy
Old Apr 8, 2004 | 12:19 AM
goober35's Avatar
918's are rated for .600 lift so yes they will work. But they wont work for long.
Old Apr 8, 2004 | 10:00 AM
1998redcoupe's Avatar
Should work because I ordered the diamond pistons with 2cc reliefs in them from Paul at ThunderRacing verifying that the T-Rex would Fit in there at .608/.612 with shaved 5.3 heads. I can go with more lift if i want to. You should be fine but definitely upgrade your springs. a broken spring can either be a quick fix or an expensive lession.
Old Apr 8, 2004 | 12:36 PM
DenzSS's Avatar
With a .030" mill, it is going to be very close. Make sure and check it.
