decent combo??
Old Sep 18, 2012 | 03:33 PM
bmfIROC-Z's Avatar
Default decent combo??
2001 z28 A4,PRC 2.5 5.3L heads,MS3 cam,Tune(Madtuner)ported LS6 oil pump,LS2 timing chain,Bosch 42lb injectors,Racetronix 255 fuel pump,LS6 intake(stock),lid,ported stock TB and MAF,Pacesetter LT headers,Pacesetter ORY-pipe(not sure on catback yet)SFC's,BMR tubular LCA's & PHB,Vigilante or yank 4k stall,Trans-go shift kit,3.73's and Nitto drag radials(preference),just wanted to get some opinions on this setup before i bought anything..
Old Sep 18, 2012 | 04:54 PM
bmfIROC-Z's Avatar
Im kind of a newb to this forum and lsx's as well,so any input would be greatly appreciated!
Old Sep 18, 2012 | 05:54 PM
JustAFooL's Avatar
That combo will be great I think. Just remember though the magic stick cams are big. The motor will be spinning pretty high to be in its best power. You could look into smaller cam and probably make more broad power. To each his own though..
Old Sep 18, 2012 | 06:00 PM
LS1T56FTW's Avatar
Cam is too big IMO. I made 470whp with a 228/232 cam. Those heads match better with a smaller/torquey cam IMO. If I were to put a donkey dick cam in my car like the one you chose, I would at least run the ported LS6 heads that TSP sells.
P.S. Power under the curve>peak numbers.
Old Sep 18, 2012 | 07:00 PM
bmfIROC-Z's Avatar
[QUOTE=LS1T56FTW;16734279]Cam is too big IMO. I made 470whp with a 228/232 cam. Those heads match better with a smaller/torquey cam IMO. If I were to put a donkey dick cam in my car like the one you chose, I would at least run the ported LS6 heads that TSP sells.
this is why i asked before i bought anything...those are nice numbers though..what cam are you running comp,custom?
Old Sep 18, 2012 | 07:37 PM
LS1T56FTW's Avatar
228/232 on XER lobes with 111LSA. I ordered the custom cam through Texas Speed (who sources their custom cams to Comp Cams) when I ordered my heads/cam package from them. My car peaked at 6550 with an LS6 intake and the power does not really start to drop off until about 6900. Just my 2 cents but spinning past 7000 is too much for a V8 street car. If you don't want to go custom, I would just run their Torquer V2 cam.
Old Sep 18, 2012 | 09:04 PM
bmfIROC-Z's Avatar
the torquer v2 cam seems like a peppy cam,what other cams go good with the PRC 5.3L heads??
Old Sep 18, 2012 | 10:00 PM
TXZ28LS1's Avatar
Lots of PRC 5.3/MS3 combos.. check out the dyno section
Old Sep 19, 2012 | 11:03 AM
bmfIROC-Z's Avatar
How about the streetsweeper tq cam??..would that be a good cam to compliment the PRC heads?
Old Sep 19, 2012 | 11:12 AM
thunderstruck507's Avatar
Without having a built trans, a lower RPM for shifts will help it last longer.
Your combo does sound like a pretty well thought out one, but I think you can get great results and more under the curve power from a slightly smaller cam (in the 230s) without feeling like you went too small.
I felt my 230/238 was a good step up from my old 230/224 but am not left wanting a bigger cam. It performs well under normal driving but still pulls excellent all the way to my 6500 shifts and likely would go further before dropping off...I just don't want to spin that high on stock rod bolts.
Old Sep 19, 2012 | 11:22 AM
LS1T56FTW's Avatar
That is the cam I based my custom cam off of. Not sure what lobes they use though. They want like 450 for that cam, or you can get a custom cam for 300 right from comp. Not worth an extra 150 dollars for quite possibly no gains whatsoever.
Old Sep 19, 2012 | 11:25 AM
bmfIROC-Z's Avatar
Maybe i should give you guys a lil more info..I know a guy with these heads, and i know they are a damn good bang for the buck head so I'm looking for a good all around street/strip cam to Go with these heads, I'd like it to be decent around town,put down around 425+whp,and run in to at least the 11.80's all motor,I know I'm being kinda picky but I'm selling my 11 sec LT1 IROC that ive had for 10 years and built from the ground up to fund this project,so I wanna do it right the first time,what cam would be best to fit this criteria?
Old Sep 19, 2012 | 11:56 AM
bmfIROC-Z's Avatar
@ls1t56,could you post your cam specs?,I think I might give comp a call..
Old Sep 19, 2012 | 01:15 PM
You could also call Texas Speed and let them put in the order for you. They can also help you spec a good cam for your goals and might even have something on the shelf that is up your alley.
Old Sep 19, 2012 | 04:21 PM
john563's Avatar
i have those heads with a 232/238 cam..very happy with the combo
Old Sep 19, 2012 | 05:35 PM
LS1T56FTW's Avatar
Done.
