Need help choosing a cam...
Old Sep 20, 2012 | 12:22 AM
DomesticNoob's Avatar
Default Need help choosing a cam...
I did my research but wanted to get your opinions on which cam to run in a stock LS2.
The car is used at the track only so nothing really matters to me other then power gains and I don't want the car stalling.
Final drive is 3.90 and will be running 100. Thanks for your input!
Old Sep 20, 2012 | 08:12 AM
J Glen's Avatar
What kind of goals and budget do you have?
Old Sep 20, 2012 | 08:18 AM
2nd Gen Fl 'bird's Avatar
This needs to be in the Gen IV section, not Gen III
Old Sep 20, 2012 | 01:41 PM
As much torque as possible, mid-low end power. The cam cost isn't really a factor.
Old Sep 20, 2012 | 05:51 PM
screaminz847's Avatar
I'm confused - if it's for track only, why mid-low end power? Are you launching at idle? short shifting for fun?
If its a track only car and you aren't looking for super good street manners, go BIG. Proven to make more power. You'll have to shift high, but it will make the power.
Old Sep 20, 2012 | 08:46 PM
garygnu's Avatar
look at a EPS truck cam.or thunder racing has some cams that mite fit your needs.maybe look at comp 54-455-11.its a torque cam .check it out on cam quest 6 at comp cam.
Old Sep 21, 2012 | 12:01 AM
jbro90's Avatar
T Rex ms4 are really good big cans
Old Sep 26, 2012 | 12:49 AM
ejbta2's Avatar
I just bought a 54-428-11 comp cam 228/230 571/573 112+4 lsa I like it so far I am breaking in my engine can't wait to take it to the track and get some times.
