97/98 LS Engine Headgasket ?
Old Sep 24, 2012 | 10:33 AM
txh0tb0i972's Avatar
Default 97/98 LS Engine Headgasket ?
Well i have been searching but i dont seem to find the right answer....but Can I use a 241 head on a 97 / 98 block?
2nd Question- Upon reseach as long as i am using the MLS gaskets i can use the 241 heads correct?
If not i will have to locate the 853s and the correct gaskets
Old Sep 24, 2012 | 10:56 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yes, you can use any of the LS1 heads on the 97-98 blocks! The standard GM MLS gaskets will work on the 241's and 243's and that block as well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 24, 2012 | 12:25 PM
Sweet!!! Thanks for the help.
