231/237 or G5X-3
I will be building a new motor for my car, and was wondering what cam to go with. I have heard alot of good things regarding the TSP cam, and also with the G5X-3 cam. I know its a newbie quest., but what is the specs on the G5X-3 cam?
Thanks,
Joe
When comparing the 2 cams, there really nothing alike. The X-3 is much more severe on the valvetrain due to faster ramp rates, and the TSP is on a much "softer" ramp rate which will be easy on the valvetrain. When it comes down to it, the X-3 will make better power "under curve" due to the faster rate getting the valve open sooner. It will also make better peak because it is a bit bigger than the 231/237. When it comes down to it, do you want mild or wild?
When comparing the 2 cams, there really nothing alike. The X-3 is much more severe on the valvetrain due to faster ramp rates, and the TSP is on a much "softer" ramp rate which will be easy on the valvetrain. When it comes down to it, the X-3 will make better power "under curve" due to the faster rate getting the valve open sooner. It will also make better peak because it is a bit bigger than the 231/237. When it comes down to it, do you want mild or wild?Trending Topics
Now forgive my ignorance but how hard is it to replace the springs?? And is that with all hard running or not?? I tend to be soft most of the time when not racing
Thnks for the info
-Matt-
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
