Oil on spark plug..
Old Oct 4, 2012 | 01:06 PM
streetknight2's Avatar
Default Oil on spark plug..
Changed plugs last night and the # 3 cylinder had what appeared to be oil on it.
The one on right.
What should I look for?
Old Oct 4, 2012 | 01:26 PM
mark21742's Avatar
First thing I'd do is pull the throttle body off and see if you have oil in the intake....if so I'd put a catch can on the car, run it for a while then check the plugs again
Old Oct 4, 2012 | 01:48 PM
Thanks, ill check it out
VandykeT/A's Avatar
I agree with the catch can but I would also pull a valve cover and see if I could see the valve seal on that cylinder. I had a valve spring break and it shredded a seal. It burned quite a bit of oil until I found it though.
Old Oct 4, 2012 | 02:03 PM
99Bluz28's Avatar
Yeah, if you have more then a thin film of oil in the intake I'd order a CC and pull the intake to clean it along with the intake ports on the heads. It might also be a bad valve seal on #3.
