Swapping from a milled head to a non milled head.
Old Apr 9, 2004 | 11:58 AM
NataSS Inc's Avatar
Default Swapping from a milled head to a non milled head.
I have been giving this alot of thought lately. Right now I have the MTI stage 2 LS6 heads and X1 cam with ALL the boltons. At the time I got this combo it was the big dog on the street. But as of late I have been seeing more and more HUGE cam combos. My problem is that with all of the huge cams I cant run them due to the MTI heads being milled .030. Would there be much gain in going back to a non-milled Stage 2 LS6 head and one of the new monster cams.
I am really looking into the grand am cam:
239/251 294/306 .570/.570 106lsa.
Any input would be appreciated.
Old Apr 9, 2004 | 12:03 PM
11secLS1's Avatar
Why not just fly cut the pistons or intall some aftermarket pistons with valve reliefs?
Old Apr 9, 2004 | 12:13 PM
NataSS Inc's Avatar
It would take some huge reliefs to accomodate this cam with the milled heads. Enough that I would be concerned with the integrity of the stock pistons. I would porbably have to fly cut them anyways, but the non milled head gives me more room to play with.
Old Apr 9, 2004 | 12:55 PM
DenzSS's Avatar
I would always swap to a non-milled head. It gives you a lot more wiggle-room and you can always weld and re-work the chambers to get your required chamber colume.
Old Apr 9, 2004 | 03:30 PM
YsoFast's Avatar
NataSS Inc,
If you want to sell those heads and cam let me know because I am going for the same setup you are currently running. Ok so it will be in a 90 Iroc with an LS1 but the engine setup will be the same.
