Thoughts on EPS cams?
Old Oct 8, 2012 | 07:44 PM
My6speedZ's Avatar
A good tuner can make even the larger cams run pretty tame.
Old Oct 8, 2012 | 07:45 PM
Grr's Avatar
Grr
234/239 lxl/huc cam is WAY different than a 236/248 eps lobed cam in the link I posted. If you want to do any amount of driving like you state the EPS cam is entirely too big, unless you want to drive around in 5th all day, it WILL surge unless you spend big money getting it tuned in
the cam martin listed in that thread is what I would switch to if i drove my car more than a couple times a week. And like I said, no way I would DD my own car without the massive compression I have, it still drives like **** up to 1800rpm the way it is bucking with the converter locked
Old Oct 8, 2012 | 07:47 PM
KingPin1094's Avatar
Originally Posted by My6speedZ
You never answered if you were going to be doing gears.
I run a 240/244 cam on the street, drives good with 11.5:1 compression. 4.10 gears made a night and day difference. It drove like **** with the 3.42.
Here is the kicker though. I wouldn't have picked a cam this large if I would have changed the cam, something like the EPS 214/232 would be better for you I think since your not trying to milk ever last drop out of your set-up. You having the heads milled any? What is your desired compression ratio?
My cam was already installed in the long block I was getting, if I would have been picking a cam it would not have been this big, I don't mind it thought since it is a nice weather car.
Edit: looks like you posted that stuff while I was typing
As long as i can run pump gas so anywhere from 12-11:1 so you think i should go with a smaller cam, gain some mpg, and still have plenty of power?
Old Oct 8, 2012 | 07:54 PM
BigBirdLS1's Avatar
This is a over simplification of everything but if you were to run a 243 head done by a well known CNC program and through a 234/238 around .610 lift or so with 11.1 CR it will with a good tune make great power be driveable and run perfect on pump gas. I would however at least throw some 3.90 gears in there.
Old Oct 8, 2012 | 07:57 PM
Originally Posted by BigBirdLS1
OP look at my sig and my setup is no where near radical. Also this thread may be of some help to you. Pay attention to my post in that thread.
Disclaimer: I am by no means an expert just giving my opinion and giving my personal experience.
https://ls1tech.com/forums/generatio...veability.html
i saw that thread and i liked the way your car was set up. however i want more hp without n2o. im looking for 450whp or better
Old Oct 8, 2012 | 07:59 PM
So if i go with that cam, what heads should i get? and can the rest of my setup stay the same? It looks like id hit the goal of 450hp with that cam and the rest of my set up
Old Oct 8, 2012 | 08:02 PM
Grr's Avatar
Grr
if you call up martin he would be able to suggest the rest, what you have listed is good but IMHO the TFS heads are a little better than the TSP heads. Always cheaper to buy everything from one spot and save on shipping or get a package deal. You could run pretty much any head if you have the 241's yet send them to AI for their high compression cnc package even and save some money, those are great heads for the $$
Old Oct 8, 2012 | 08:06 PM
BigBirdLS1's Avatar
Thanks for the compliment. I made really close to 450rwhp on motor. Actual motor numbers were 445rwhp and it made over 500rwhp on the spray.
My6speedZ's Avatar
You final compression will depend on the cam specs.
Static compression is basically juse the volume in side the cylinder available. Your dynamic compression is the compression made once the valves are close.
That cam I listed was just the smallish one listed on EPS's website.
I personally, when I was planning my H/c build before I bought my longblock was looking at the VRX4 cam from Vengance racing, it is 228/230 .588/.592 XER.
You will make good power with that compression, and a street cam will give you great usable power. Gears will also make the car feel alot more natural, 3.90 and 4.10 are pretty much the go-to gear for the t-56 guys.
Old Oct 8, 2012 | 08:07 PM
Alright thanks everyone for the postive feedback. Ill have to give martin a call and figure out what cam and heads to get. Hopefully ill still make 450whp+ with the smaller cam. Again thank you for the input.
Old Oct 8, 2012 | 08:08 PM
Alright ill keep that in mind.
Old Oct 8, 2012 | 08:13 PM
  #32
My6speedZ's Avatar
I have seen 2 seperate cars put down 450-460 on Ai226 243's and EPS 226/234. So your goal is defiantly possible with a good driving cam no reason to kill your power band for some high RPM power if your not going to be tracking the car alot.
Old Oct 8, 2012 | 08:26 PM
  #33
BigBirdLS1's Avatar
I know of 2 cars locally that have some kind of CNC'd 243's with a midsize cam and both of them are in the 440-460 range. Like I said it doesn't take a HUGE cam to make HUGE numbers.
A great engine builder I know said "that you could have the best cam in the world with a set of cookie cutter heads and not make good power. If you have a good cam with a great set of heads it will make HUGE power.
Old Oct 8, 2012 | 08:27 PM
  #34
Well the 236/248 said it had an 1800-7200 power band which i thought was pretty good. But ill definitely look into the smaller cams, and i pm'd martin and ill get his opinion. Thanks guys
Old Oct 8, 2012 | 08:30 PM
  #35
BigBirdLS1's Avatar
You are on the right track OP. I never claimed to be an expert but Martin is and there are some experts on this site also. I did my fair share of brain picking when I was deciding what parts to buy. Just be honest to yourself and whatever expert you ask about your wants/goals then you will be happy. I'd hate to spend all that money on parts then not be happy with the end result.
Old Oct 8, 2012 | 08:31 PM
  #36
My6speedZ's Avatar
I know Martin, he will set you straight.
Old Oct 8, 2012 | 08:38 PM
  #37
alright thanks guys
Old Oct 9, 2012 | 08:39 AM
  #38
Sales@Tick's Avatar
Thanks for all the compliments guys.
OP that 234/239 112+3 cam was a great cam for Bwolf's valve-train he had to work with.
He was using TFS heads and aftermarket roller rockers which greatly increase the weight of the valve-train and care must be taken with lobe selection to not upset their stability.
I would have a valve job performed on the stock valves and use them. Most of those aftermarket 2.04 intake valves are around 100-110g where as the stock valves are 90ish and sodium filled 243 intake valves are 78-80g...HUGE difference. Stock rockers are the lightest rockers available for LSx engines.
All that said we can use a slightly more aggressive lobe selection with your set-up to gain some torque in the low speed and mid-range areas.
I would do something like my Stage 2 Street Heat cam from our Elite Series of camshafts. http://www.tickperformance.com/tick-...1-ls6-engines/
Or if you really like Bwolf's profile I have this cam also: http://www.tickperformance.com/tick-...r-ls2-engines/
We could also do something custom like 235/240 .621"/.588" 113+3.
If you wanted to focus a little more torque down low and shift the top end of the torque curve back into the meat of the power band, we could do something custom and take some exhaust duration off that profile and tighten the lobe separation up to a 112+3. It would look like 231/236 .617"/.578" 112+3 or we could still hang a little more torque out in that area and sharpen the torque curve by taking the lobe separation from 113+3 to 112+3. Shortening the exhaust duration and tightening lsa have similar effects, but not identical as you're also removing overlap when you remove exhaust duration.
All of the profiles I just mentioned have slightly different characteristics and different power curves with different peaks and average numbers.
Old Oct 9, 2012 | 09:32 AM
  #39
BotlFedZ's Avatar
I also vote smaller cam. I bought my car with the thunder racing raptr cam 236/242 - .615/.615 - 111 lsa then added the 220cc trickflow heads milled a bit and the best it made was 429/387 with no low end power at all. I then talked to ron at vengeance and he told me to go with the vrx5 236/238 .601/.605 113 LSA and it made 456/404 with better drivability and alot more power down low. All his was thru 3.42s and a stock ls6 intake. Just my experience with a larger cam to smaller.
Old Oct 9, 2012 | 04:13 PM
  #40
Well im looking to get the most hp/tq out of this LS1 and still get 15-22 mpg. Id like to have a broad power curve. With that said what duration would you recommend? also It sounds as if you recommend the 243 heads? correct?
This might also sound.. noobish, but what effect does LSA have on power and power bands? and drivability?
