Heads/Cam LS1 using oil?
I have posted on here a few times about my build. If you have any questions on it let me know, the full build thread is on here. Anyway I have about 2000 miles on my build, and I have had to add a quart of oil to my motor since then, and it is actually still slightly low. I recently put a catch can on the car (within about 500 miles I would say) along with the "revised PCV valve" but it seems that my car is still going through oil rather quickly. If I had to guess it would probably go through about 2 quarts in an oil change (3000 miles). Any ideas of what could be causing this? The entire top end is new. My buddy told me that sometimes you have to put sealant on the rocker bolts because oil can blow thru on certain casting heads? I am willing to do that, but I was not sure if that was the issue or what?
Any advice is greatly appreciated.
Thanks.
