LS1 to LS3sawp?
Old Oct 14, 2012 | 04:25 PM
Possum Boggs's Avatar
Default LS1 to LS3sawp?
what is needed to swap a ls3 into a 98-02 f-body?
Old Oct 14, 2012 | 05:07 PM
litle88's Avatar
Will your top end be Ls3 as well?
Need more info on the swap bud
Old Oct 14, 2012 | 09:33 PM
i was just looking at some ls3 motors as an option,id like to swap a complete motor,ls3 top end and all
Old Oct 14, 2012 | 09:48 PM
wondering if the computer would need reprogrammed and if there was any issues with things not plgging up right as far as the alternater connector,other sensors
Old Oct 15, 2012 | 12:32 AM
Exidous's Avatar
It would require a complete retune and either a reluctor swap or an adapter box from lingenfelter.
Old Oct 15, 2012 | 08:34 PM
litle88's Avatar
It will run, I did it. You'll need your Ls1 knock sensors bolted to the side of the block, one on each side. Map sensor extension, cam sensor extension but this harness comes with the knock sensor extensions. Other than that the Ls3 has 58xtooth reluctor wheel for the crank sensor and the Ls1 has 24x tooth so that why you'll need the LPE converter box. You'll also need to convert the timing gear to a 3 bolt cam sprocket and put a 4x bump on it. LPE' web site has all that info that's pretty useful.
http://www.lingenfelter.com/page/ls-...lector-id-page
