Any problem with stock head gaskets?
Old Apr 10, 2004 | 11:00 AM
98_1LE's Avatar
Default Any problem with stock head gaskets?
?I already have a set of stock head gaskets, but have since had Cometics recommended. I was wondering if there were any reliability issues with the stock head gasket, and if it was worth upgrading at this point. What would the advantages be? I will be using ARP head studs.
Old Apr 10, 2004 | 11:12 AM
Nasty N8's Avatar
The stock head gaskets are very good. I use them for most heads and cam applications. Unless you need some odd thickness no need to switch.
Nate
