Another PR Double-Check Me Thread
Old Oct 18, 2012 | 09:24 AM
themealonwheels's Avatar
Default Another PR Double-Check Me Thread
I hate seeing so many of these threads out here, but after measuring my setup, I can understand why they keep showing up! My setup is a 346 LM4 with gm mls gaskets, ls7 lifters, ls6 cam, trunnion upgraded stock rockers and 799 heads milled to 62.5cc chambers, I'm pretty sure that's ~.015" milled.
I used the comp cams pushrods length checker and came up with 9.5 turns to zero lash. So I did 6.800"+(0.050" * 9.5)= 7.275" + 0.075" for preload and got 7.350".
Is that right, or does gauge length come into play here? It just seems like that combo should require a longer pr... But that's why I checked. I would check against a stock pushrod length, but the motor I'm replacing is not out yet. Any input from the experts out there (vettenuts) would be really appreciated.
Old Oct 18, 2012 | 09:33 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Your method here is correct. Although we typically shoot for .050" preload, anywhere between .40"-.090" will work.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
