HP limit of Eagle Rods?
Old Apr 10, 2004 | 03:53 PM
2001CamaroGuy's Avatar
Default HP limit of Eagle Rods?
I have a set of Eagle rods I'm going to be using in my new engine. They have the ARP 8740 Chrome Molley rod bolts in them now.
Does anyone have an idea of these rods HP limit?
Would I gain anything having ARP L-19 bolts installed? Would I need to resize/rehone if I change rod bolts?
Old Apr 10, 2004 | 04:22 PM
PNYKILR's Avatar
This car has eagle rods init, and it pegs the dyno with ease. No telling how long they'll last though. Nothing like a 1.34 60' on the back tire.
turbo stang
Old Apr 10, 2004 | 04:37 PM
vid won't work for some reason. What kind of HP numbers did it put down? I'm hoping to make about 600 crank (500rwhp). I MIGHT (still don't know) do a 100-150 shot some time down the road just to do it but I'm not sure yet.
Old Apr 10, 2004 | 05:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I make 746rwhp with Eagle rods and L19 ARP rod bolts.
Old Apr 10, 2004 | 05:32 PM
PNYKILR's Avatar
The mustang made over 1200rwhp. I think you'll be ok.
Old Apr 10, 2004 | 05:35 PM
Jason99T/A's Avatar
I can shift faster than you.
I would highly recommend the L19 bolts. I would also have your machinist check the housing bore of the rods regardless, especially if the bolts are changed. Eagles rods are good rods for the money, but they do need to checked out of the box prior to assembly.
Old Apr 10, 2004 | 06:02 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Exactly what Jason said! Go with the L19 hardware and recheck the housing bore. You will be fine at your expected HP.
