idle speed after cam install
Old Apr 11, 2004 | 11:16 AM
yellowbird's Avatar
Default idle speed after cam install
what should the idle speed be with a A4 after you have installed a 224/224 with headers and is it normal for it to be a little rougher at first when its cold.? oh, Its a 2002 t.a. and I did have it mustang dyno"d.
Old Apr 11, 2004 | 11:25 AM
2000Blackout's Avatar
Its going to idle low,I believe mine idled at around 500-550,and it used to die at every light.You will need to get a tune to turn the idle up.And yes its normal for it to run rough when cold.Welcome to having a cam.
Old Apr 11, 2004 | 11:33 AM
yellowbird's Avatar
yea, I did have it dynoed right after , and it idles around 800-900 and it doesnt stall.throttle response is tremendous, especially with my 373 's and my 2800 stall.also is it common for it to smell a little rich at first when its cold.no smoke or nothing just a little more richer then when its warm.
Old Apr 11, 2004 | 11:35 AM
What did you dyno? What lsa did you go with?
Old Apr 11, 2004 | 11:44 AM
yellowbird's Avatar
it dynoed at 436 chp and about 360 rwhp, and it was done on a mustang dyno.
Old Apr 11, 2004 | 03:41 PM
99ssleeper's Avatar
What other mods do you have besides the cam, 3.73s, and stall?
How did you raise your idle? Drill the TB hole?
Old Apr 11, 2004 | 07:45 PM
yellowbird's Avatar
kooks headers, corsa exhaust,jantzer ported t.b.,slp ramair kit,trans-go shift kit and 160 degree thermstat.
