Need some help with a few small things
First, does anyone have a part number for a 5.3 piston ring set? I only need one, broken ring land.. replacing piston and need to rering.
Also, Is the oil pump mounting bolts the same as the bolts on the rear cover? Im piecing the motor together and don't have any bolts!
Could use a pic of the oil pump bolts if its different.
Thanks
Thanks
well, thanks man! I need the motor mount to engine block bolts, 4 valve cover bolts, front cover, oil pan, oil pump, cam retainer bolts, intake bolts, header bolts, water pump bolts.. umm im sure theres more, but thats where im at off the top of my head.
oh.. and does anyone know if rod bolts are reuseable? iv read yes and no.. would like a solid answer.
