450+ hp LQ4 Build on a budget
Old Mar 25, 2013 | 12:00 PM
  #41
Spec134's Avatar
Just a quick update.
I've been doing some bargain hunting and was able to get a lot for what I believe to be a good deal.
Meiling oil pump M295 - $40 (new)
LS2 timing chain & gear set $35 (new)
PAC 1219x - $150 (used less than 100miles)
Rockers & trunnion upgrade - $140 (used/new upgrade kit)
92mm TB w/IAC & TPS sensor - $190 (new)
Stock head gaskets and complete bottom end gaskets - $130 (new)
I'm still need to purchase my new pushrods. But I'm unsure of how to measure. Can someone please explain to me what I must do? I've tried searching but still a little unclear to me.
Also I lucked up on a LS6 valley cover from a friend. After doing a little research I've read that this will help improve oil consumption on the older gen III. I would prefer not to use a catch can. I'm hoping that I will only need a breather for the passenger valve cover and intake to cover tube.
Old Apr 1, 2013 | 01:04 PM
  #42
Spec134's Avatar
****Quick update****
Turns out the engine is not a 02 unless the 02's came with 2nd version bolts. I think it may now be a 04.
I've include a couple of pics of the progress.
Engine teardown
Piston and block cleaning/prep
Paint
Heads and intake install
File Type: jpg
Old Apr 3, 2013 | 05:41 PM
  #43
JJMclure's Avatar
What'd you use to clean the piston tops? Looks like they came up pretty good, also looks like you got chit loads more room to work on your engine than I do mine!
Old Apr 3, 2013 | 08:41 PM
  #44
Spec134's Avatar
JJMclure check this website out it helped me out with the piston clean up. http://www.mach1restoration.com/how-...hold-products/
Old Apr 4, 2013 | 09:34 AM
  #45
moeZ28's Avatar
Nice build...I'm doin about the same thing only with a g5x3 112 and milled the L92 heads 0.020". I'm hoping to make 430or so at the tires.
Old Apr 9, 2013 | 03:13 PM
  #46
DC True's Avatar
Love the color. Great build so far. Keep the updates coming.
Old Apr 15, 2013 | 04:26 PM
  #47
Spec134's Avatar
Had a pretty productive weekend. Almost done just a couple of things here and there to get. Then should be good to plug in.
Old May 14, 2013 | 02:27 AM
  #48
Chi_weezy's Avatar
Good job man. Looks awesome. Can't wait to start my build.
Old May 15, 2013 | 02:56 AM
  #49
Ronny_02_WS6's Avatar
Looking good, what intake is that???
Old May 19, 2013 | 04:20 AM
  #50
RezinTexas's Avatar
Engine teardown
Those LS2-style lifter trays are another indication that you have an '04+ motor.
You can also check the connecting rods, they are probably LS2-style as well.
Old Jun 21, 2013 | 05:04 PM
  #51
Spec134's Avatar
It is the LS3 intake.
Old Jun 22, 2013 | 01:48 PM
  #52
KingPin1094's Avatar
Thats a pretty tight budget, but i did a 408 with a forged bottom end and a relatively stock LS3 top end, and made 440whp on a stingy mustang dyno through a t56. The tuner said its close to being a 10 second car just needs a set of gears. I think i put about 4k-5k into the motor. I daily drive the car and its really pretty streetable. Best mpg so far around town is 17.2, if your worried about that at all.
Old Feb 16, 2014 | 01:38 PM
  #53
iliveonnitro's Avatar
I'm doing something similar now. Any updates?
Old Feb 17, 2014 | 12:29 PM
  #54
saylorZ28's Avatar
i'm planning a 408 or 413 build my LS3 heads will be here this week. trying to decide to spray or boost. i'm leaning toward boost just because i feel there is less shock to the drive train, this is good info subscribed
Old Mar 20, 2014 | 01:30 PM
  #55
Spec134's Avatar
No updates as of yet. Had to take a little timeout to work on a few other things.
Old Mar 24, 2014 | 05:27 PM
  #56
possessedsaint's Avatar
you have an updated list of all the parts you have put in to this so far and the total?
Old May 10, 2014 | 08:21 PM
  #57
1975delta88's Avatar
Glad I found this thread. I also have an LQ4 that I plan on using LS3 heads, but all the info I can find is LQ4 with L92 heads with a Carb. I need efi.
Old May 11, 2014 | 07:27 AM
  #58
tashspop's Avatar
thats what i was thinking. if so finding some pistons to bump comp should be easy.
Old Jul 25, 2014 | 07:28 PM
  #59
JAYSS10's Avatar
ok guys im doing a lq4 build for a 82 s10 its a street strip truck more strip than street it is a budget build ,I have a 350 trans and 4400 stall ,I have 243 heads for it and shortie headers,ok what cam will fit in this setup with out pistion notch and will the truck intake work good ,I want a mid 10 sec truck ,4.10 gear 27 tall tires and I have hp tuners its a 2006 motor vin u ,I also need a stand alone harness for ele pedal set up prices on stuff also if you can and if you have some used stuff I can use please offer
Old Jan 18, 2016 | 04:16 PM
  #60
Bowtie423's Avatar
Originally Posted by low2001gmc
for a strong daily driver, the 6.0 will do great with a 228-232 cam, tbss or nnbs truck intake and tb, long tubes, underdrive pulley, mill the 317s .030 to bump compression up to work with cam, 3600 stall and at least 3.73s. 6.0s kill trannys so either 6 spd or 4l80 is your best bet. feel free to pm with any ?s you may have....good luck with your project, rob
I'm just now starting to build a LQ 4 motor what suggestions to get 450 horsepower for the cheapest price
