ls1 and lq4 flex plate...is mine correct?
Old Nov 10, 2012 | 05:11 PM
ldyzluvdis06's Avatar
Default ls1 and lq4 flex plate...is mine correct?
just picked up a lq4 out of a 05 2500. looking to bolt up my SS3600 stall and flt 4l60e trans. i noticed that the flexplates look a little bit different, and figured i might as well post up to find out if i will have any issues here...? thanks in advance.
5.7L LS1:
6.0L LQ4:
Old Nov 10, 2012 | 05:56 PM
chrisfrost's Avatar
I would do a Google search if I were You
Old Nov 10, 2012 | 08:55 PM
I did search and read that they should work since the lq4 is post 00. The ls1is out of a 98 if that matters. What I read it should work but I just want to check since the flexplate actually look different.
My 5.7 is completely flat, but the lq4 is sunken in a little bit with raised converter mounting points. (well, that's what it looks like at least... Lol)
Can any one confirm if it will work or if something needs to be done to make it work, this is a dd and need it on the road.
Old Nov 10, 2012 | 09:01 PM
badazz81z28's Avatar
Is there a GM part # on it to cross reference? GM might have changed the design or the manufacturer. Mechanically the same but visibly different...
Old Nov 11, 2012 | 02:23 PM
No visible part number on either one.
Someone has to know the answer to this please. A sponsor or something. I don't want to put it all back together and in car just to drop the trans to change the plate later when I find out it doesn't work.
Old Nov 11, 2012 | 02:47 PM
I don't see why you can't call the manufacturer of the Converter and ask if it will work on a LQ4?
If the diameter, bolt pattern, depth is the same, no reason why it wouldn't work
Old Nov 11, 2012 | 02:53 PM
My research is showing me the difference between LS flexplates is the bolt pattern for the converter.
Old Nov 11, 2012 | 09:02 PM
miker2's Avatar
that might be the flat flexplate for a 4l80e. remove it and check for a spacer . the flexplat for a 4l60e is dished towards the crank and does not use a spacer.
Old Nov 12, 2012 | 11:31 AM
just an update in case anyone else has this question...
i contacted texas speed and they instructed me to just swap the flexplates and be sure to remove the spacer on the 6.0
