Route to go with 6.0 (Drag Racing Oriented)
I opted to use L92's but I found a good deal on some flat tops here on the board. Cut them .030", Pats cam (I did have to flycut) vic Jr, etc and I'm happ, car has been 10.50's @ 128.
Since you asked about fly-cutting, you could fly-cut the pistons and mill your heads for an ever higher compression ratio which I would highly recommend.
The car will only respond better to anything you throw at it with the higher compression it would have.
The added overlap will also help focus torque in this area along with opening the exhaust valve a little bit later than I normally would like. It being a drag oriented set-up, overlap is not something I'm worried about and will only help make more power where it's needed.
With this camshaft at least 11.5:1 if not 11.7-11.8:1.
So 2 questions lol
ARP main studs ( Got with my 6.0)
New Rings
New main bearings
ARP rod bolts
Milled heads .040
Fly cutting the pistons is still up in the air as to how I'm going to do it
Then the bottom end should be done and ready to spin I didn't even ask ya Martin where do you think this cam is going to want to shift at with the 243's?
