Stock Pushrods with PAC 1218 springs?
http://en.wikipedia.org/wiki/Buckling
The Area Moment of Inertia (I) is a big player in column stiffness. As vettenuts has said, the pushrod OD and wall thickness determine the overall I value. Also, Modulus of Elasticity (E) is a factor ... so material properties does also play a role. Increase both I and E and you have a much stiffer pushrod.
http://www.mantonpushrods.com/
