Forged Crank and Rods for 5.3
Old Nov 13, 2012 | 09:29 AM
Bonnie Rampage's Avatar
Default Forged Crank and Rods for 5.3
Summit Racing does not list a Forged Crank for a 5.3 Any help finding one would be great. Im very new to this so also any tips would be nice IE Cam, Rods, Pistons. Im putting a D1SC on it with a blow through Carb. Im open to all ideas bc I have no idea on what set up would be best. The only rock solid ideas so far are the blow through and the D1SC. Thanks
Old Nov 13, 2012 | 09:31 AM
Also, it has a 24 tooth Reluctor Wheel in it now. Not sure if that matters with a new crank or not. Its an iron block.
Old Nov 13, 2012 | 09:50 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Are you looking to stay stock stroke, or go larger? We offer a few different brands that will work with your setup.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 13, 2012 | 09:55 AM
As I am new to this, do you have to do any work to the block to have a longer stroke? If so how much work is needed?
Old Nov 13, 2012 | 10:24 AM
batboy's Avatar
If the block needs to be bored anyway, just bore it to LS1 size and use a forged 5.7 rotating assembly.
Old Nov 13, 2012 | 11:08 AM
The block looks good so I do not need to bore it over any. I would like to keep the walls as thick as I can. Im use to SBC that needed some block work to allow for a bigger stroke. IE clearing for a stroker crank. Do I need to do that for a longer stroke on a 5.3?
Old Nov 13, 2012 | 11:55 AM
96capricemgr's Avatar
why are you set on buying a crank?
Old Nov 13, 2012 | 01:42 PM
I was told if your shooting for over 500hp you needed to replace it.
Old Nov 13, 2012 | 01:59 PM
you need to ignore whomever told you that.
Old Nov 13, 2012 | 02:05 PM
Ferocity02's Avatar
The stock crank is one of the last things that needs to be replaced in the engine. Stock 5.3L cranks have seen well over 1000hp.
Old Nov 13, 2012 | 02:07 PM
So what is it good too?
Old Nov 13, 2012 | 02:08 PM
Ok so I could get away with just rods and pistons?
Old Nov 13, 2012 | 02:09 PM
redtan's Avatar
Anything over 800rwhp and it's recomended you get a stronger crank. Up to that it will be fine.
Old Nov 13, 2012 | 02:23 PM
KCS's Avatar
KCS
Moderator
What are you doing with the engine? Boost, nitrous, naturally aspirated?
Old Nov 13, 2012 | 02:47 PM
I would tend to agree with both these guys.
The people pushing stock parts 800-1000hp+ do so knowing they could lose the engine. Some do it figuring a junkyard longblock is cheaper than a forged crank, some like the challenge and notoriety that come with making huge power on stock parts. At any rate anyone saying 500ish is the limit for a stock crank is not to be trusted atall, OEM gen 1 sbc cranks are go to more than that and materials/engineering/machining on the LS series is better.
There are gen 1 and gen 2 cast aftermarket cranks that will break below that but not stock GM V8 stuff.
Old Nov 13, 2012 | 03:07 PM
batboy's Avatar
The stock GM cranks are quite durable. I'm close to 600 hp on a stock LS1 bottom end.
To answer your original question, anytime you install a stroker crank, you need to check the clearance of the counter weights and rod bolts. Sometimes a little grinding of the block is required. It's usually not much with a 4" crank.
I'd just get forged rods and pistons and call it a day. Here are the pistons you want for a 5.3 with stock crank (use 6.125" long rods with those pistons):
http://texas-speed.com/p-741-wiseco-...l-engines.aspx
Old Nov 13, 2012 | 03:17 PM
Blow through carb with a D1SC ProCharger. Maybe a 150 shot once in a blue moon.
Old Nov 13, 2012 | 03:25 PM
Thanks
Old Nov 13, 2012 | 03:26 PM
Thank you!!!
Old Nov 14, 2012 | 01:50 PM
RedRocketZ28's Avatar
You are good with the stock crank man. If it were me, I would run it as is. You got that thing cheap!!! Haha.
