977 and CompR - what is the correct preload for this setup??
Old Apr 12, 2004 | 03:04 PM
Crowley's Avatar
Question 977 and CompR - what is the correct preload for this setup??
I know there has been alot of talk with different numbers, but what is the correct preload with this setup? I will not have adjustable rockers. I am having absolute speed set these heads up and another shop install the heads.
I need these to be as reliable as possible since this is my Daily Driver!!!
Thanks,
Crowley
Old Apr 12, 2004 | 03:07 PM
SPANKY LS1's Avatar
You will need .002-.004 preload with Comp "R"s, regardless. Jay told me that I would need 7.350" PRs and .030 shims. My AS heads are milled ~.025, and I too have Comp "R"s and Comp 977s. I am having a shop with experience in setting them (Comp "R"s and non-adjustable rocker arms) up do mine fwiw. Good luck, Shawn
Old Apr 12, 2004 | 03:17 PM
2xLS1's Avatar
I have a question or two. Those that say they are setting lifter preload at .002-.004, do you really think you can tell when you are at 0 preload just by turning the pushrod with your fingers and tightening the rocker bolt and not having a dial indicator directly reading the movement of the lifter piston which you cannot access with the heads on? Have you actually looked at a .002 or a .004 feeler gauge to see what a small amount that is?
Old Apr 12, 2004 | 03:20 PM
SPANKY LS1's Avatar
Thats why someone who has successfully done this before is doing mine. I trust their experience and expertise. What other choices are available? Its this or ~$1100 in additional valvetrain ($250 valve cover spacers and $850 rockers).
Shawn
Old Apr 12, 2004 | 03:22 PM
2xLS1's Avatar
I don't care how experienced you are. Fingers cannot feel .001 inch of movement.
Old Apr 12, 2004 | 03:25 PM
SPANKY LS1's Avatar
I agree, but the difference between stock lifter preload (I *think* ~.050) and the COMP "R" preload (.002-.004) should be able to be measured/estimated. My guess is that realistically <.010 or so is fine, which I think is attainable. What other options do you suggest or recommend? I, like others in this boat would like some other options, they just aren't there.
Shawn
Old Apr 12, 2004 | 03:30 PM
2xLS1's Avatar
I have no suggestion. I just chuckle when people say they can set preload on a hydraulic lifter at .002-.004 using their fingers to feel for the starting point of 0 preload. I will say that understanding how a hydraulic lifter is put together that running the inner piston .002-.004 from the retaining clip that holds it in does not make sense from an engineering stand point.
