LS4 Impala Block
Old Nov 13, 2012 | 06:38 PM
knuts82's Avatar
Default LS4 Impala Block
Anyone know if the FWD Impala, Monte Carlo blocks aluminum 5.3's bolt up to a RWD trans or what the deal. Thanks
Old Nov 13, 2012 | 07:28 PM
batboy's Avatar
Straight from GM:
The bellhousing bolt pattern differs from the rear wheel drive blocks.
Old Nov 13, 2012 | 08:22 PM
motorsports601's Avatar
Any adapters? Or in the works?
Old Nov 13, 2012 | 08:52 PM
knuts82's Avatar
I did a little more research and found they also made the blocks an inch shorter. Sounds like a no go for RWD applications. To bad since I found a few for less then $400.
