Oil pressure
Old Nov 26, 2012 | 01:39 PM
bad intentions's Avatar
Default Oil pressure
I know this topic has been covered before and I've done a bunch of searches before I posted, but I'm new to f-bodies and just needed to check if this was normal for my 02 SS 95 thousand miles stock oil used recently mobile 1 5w30
this is what the pressure is at a stand still.
Here is what the pressure looks like while driving
Don't know if I should be concerned, or maybe the gauge went bad.
Any advice is welcomed
Old Nov 26, 2012 | 02:01 PM
Ferocity02's Avatar
I think it's fine. But you can/should use a mechanical gauge to confirm your dash gauge is correct. My gauge from the factory was overestimating the oil pressure by 10 psi, so I pulled the needle off the gauge and moved it so it's reading correctly now. Could be a bad sensor, but it works fine other than being off.
Old Nov 26, 2012 | 02:08 PM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
+1 check with a mechanical gauge to be for sure.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 26, 2012 | 02:10 PM
Thanks for the advice I will check with a mechanical gauge
Old Nov 26, 2012 | 06:28 PM
wildcamaro's Avatar
If still low check either pump pickup oring or the pump itself being worn...def verify with mechanical...
