Injector Upgrade?
Old Nov 26, 2012 | 03:57 PM
ss4chad's Avatar
Default Injector Upgrade?
Just got my new 427 motor stabbed in the car and I am thinking about having it tuned on E-85 since it is available in my area. I have the Ford Green Top 42lb injectors (flow matched) now but should I upgrade those to a 60lb (higher-lower) to run the E-85?
Will the Green Tops fair well with alcohol?
Is the 42lb enough or too much for running E85?
Thanks guys!
Chad
Old Nov 26, 2012 | 07:20 PM
muayyadf1's Avatar
For that big motor, I would go with siemens deka. They are easy to tune if you have the correct data.
http://fuelinjectorconnection.com/sh...p?productid=20
Old Nov 26, 2012 | 08:56 PM
S10xGN's Avatar
Chad, if you upgrade I'll take your old injectors if the price is fair.
Old Nov 27, 2012 | 06:26 AM
ss4chad's Avatar
What is fair?
Chad
Old Nov 27, 2012 | 06:27 AM
ss4chad's Avatar
Thanks for the link!
Chad
Old Nov 27, 2012 | 06:29 AM
ss4chad's Avatar
Anybody else see a problem with running the Green 42lb Ford on E-85? SHould I go bigger? Will the Green injectors hold up to the alcohol? Is the alcohol a problem with any injector? Since E-85 is higher octane which means less gas and more alcohol, which means more fuel consumption, does that mean i should go to a bigger injector?
Chad
Old Nov 27, 2012 | 06:46 AM
Old Geezer's Avatar
Talking Take the estimated HP
Chad
and choose an injector to add about 30% more flow over the gas inj flow. That will get you close.
Old Nov 27, 2012 | 07:39 AM
96capricemgr's Avatar
You said 427 but gave nothing to indicate what sort of power you expect or a parts list so we could make a guess. That is the first bit of info needed when discussing injector size needs.
Old Nov 27, 2012 | 08:51 AM
ss4chad's Avatar
LS6 re-sleeved to 427 Cu In
Dragonslayer 4" Crank
Compstar Rods
Diamond Pistons (Dome)
DART 250CC/68CC heads 2.08-1.60 valves
Comp Cam 256/264 - 625/625 - 113+4
Harland Sharp Rockers
FAST 90 ported
Holley 90 TB
42 lb Ford Green top injectors
Meziere Electric Water Pump
Kooks 1 7/8 headers
MSD Starter
Ported oil pump
ASP Underdrive Pulley
Performabuilt Trans Level 2
Vigilante 4200 Stall
Detroit Locker
Richmond 4:10 gears
Moser Axels
ALL Suspension components replaced with UMI suspension.
Chad
Old Nov 27, 2012 | 08:52 AM
ss4chad's Avatar
I'm guessing 575 to 600 RWHP, maybe more if I tune to E-85.
Chad
Old Nov 27, 2012 | 10:06 AM
batboy's Avatar
That much hp and E85 to boot, yeah, you'll need bigger injectors.
Old Nov 27, 2012 | 02:11 PM
ss4chad's Avatar
Called FIC, they recomend 58-60lb injectors. So it looks like I will be selling mine.
Chad
Old Nov 28, 2012 | 07:16 PM
S10xGN's Avatar
What is fair?
Chad
Dunno, $175 shipped to 77651? They'll fit in a $5 USPS flat-rate box...
Old Nov 28, 2012 | 07:24 PM
keith102371's Avatar
Compstar Rods
FAST 90 ported
Holley 90 TB
Kooks 1 7/8 headers
MSD Starter
Ported oil pump
Detroit Locker
Richmond 4:10 gears
Moser Axels
Chad
damn nice build!
Old Nov 30, 2012 | 06:54 AM
ss4chad's Avatar
Thats a fair price, I will be in touch, thanks!
Chad
Old Nov 30, 2012 | 07:00 AM
ss4chad's Avatar
Originally Posted by keith102371
damn nice build!
Chad
Old Nov 30, 2012 | 07:06 AM
ss4chad's Avatar
Ready for install
Chad
