IDK what the problem is!
Usually a pushrod doesn't just get bent. It usually results from a missed shift
As mentioned above. You really need to take a video and post it so maybe we all
Can help point you in the right direction.
We are you located? Maybe a local member can come take a look at it.
I will if you are local to me.
but ill see about making a video just have to weigh the risk/reward issues. When I really got on it a few weeks ago I would hear an odd noise so something was wearing out...I looked over as much as I could but I could never put a finger on it. And now it finally gave out. The Best V8 Stories One Small Block at Time
You could also take off the ac belt and see if the noise stops. slide under the front of the passenger side of the car and look for the ac tensioner pully. Cant remember if you need a wrench or a ratchet will work, but remove the small belt. You can drive without the ac belt if you need to, but the ac will not work.
