Identify cam?
Old Dec 2, 2012 | 08:12 PM
thefridgews6's Avatar
Default Identify cam?
Just pulled out my cam, just wondering if its stock or not, car had work done to it before I bought it but the guy did not tell me this, found out when I started pulling the motor apart, the only numbers on the cam I can find is 14:04b 02502 and that is on the center part near the front, there is also a C on the middle and an E on the back end. Is this a stock? Thanks in advance.
Old Dec 2, 2012 | 10:19 PM
NBM-LS1's Avatar
If you know the brand of the cam you can email them with the grind number on it and they should be able to give you the specs.
Old Dec 3, 2012 | 06:11 PM
Pocket's Avatar
If its stock it will have a barcode on the end
Any machine shop or speed shop will be able to degree it for you and tell you the specs
Old Dec 4, 2012 | 09:44 AM
No barcode, so I'm thinking not a stocker, any way to tell who the manufacture is?
