408ci stroker Head HELP
Old Dec 3, 2012 | 04:17 PM
transamguy24's Avatar
Default 408ci stroker Head HELP
So I am currently in the middle east and plan to build an engine when I get home. I'm gunna build a 408 stroker in a 6.0l iron block. I already have a good cam for this built; 242/248 dur 610/615 lift 114+2 LSA and the springs ect.. I'm planning on useing a 102mm lsxr and matching tb. The goal is 500rwhp. I dont know how to do the math for decideing what my head specs need to be. But I just bid on a set on ebay that are bare with 2.1/1.6 valvejobs, 240cc intake port, 95 exhaust port, 66cc combustion chamber. Does anyone have any input as to weather these heads are too big for this cam? I just dont wanna loose power.
Old Dec 3, 2012 | 04:19 PM
djfury05's Avatar
Buy some new TFS 235s
Old Dec 3, 2012 | 06:50 PM
garygnu's Avatar
any casting numbers on the heads you bid on ?they sound like l92 or ls3 heads.you can get new ls3 heads from SDPC for $650 a set..the l92/ls3 head flows great,and is a good fit for bigger bore motors.
Old Dec 3, 2012 | 07:20 PM
Sales1@Texas-speed's Avatar
We have several different options that would work great for your build. Give me call if you get a chance or send me a message I'll be happy to help you out.
Old Dec 4, 2012 | 02:22 AM
Na the guy who posted them failed to mention that he p&ped them himself and drilled through the pushrod holes into the intake ports. So I wont be picking those heads up.
Anyway the above plan is the original plan, however I told A friend and long time lsx mechanic what my budget is and he began to shun me away from building a stroker and go with a supercharged setup instead. This based off the fact that once I get home from the desert, my build budget will be $8,600. My only problem is that I don't want to go with a junkyard engine because the last one only lasted a year before It took a **** through the oil pan. And I don't know much about forced induction but I just cant comprehend the possibility of building a strong long lasting engine and supercharge it on this $8600 budget. I know this is kind of off topic but from a newbie to all you professionals out there, What would you recommend on an $8600 budget? Build the stroker or supercharge a junkyard motor?
Since I already you will ask, my goals are to make 500rwhp or more while knowing it will last for a good long time. Its an 02 ws6 that I'm planning to make mostly a weekend toy(some drag racing) with decent driveability so I can daily drive it if I choose without having complications.
Old Dec 4, 2012 | 09:38 PM
Tainted's Avatar
Theres cam only ls3 cars making 500+ rwhp
My recommendation:
Low mileage LS3
Trickflow heads
Fast intake
Custom cam
Supporting mods
Hello 500+ EASY rwhp for less than 8k
Old Dec 4, 2012 | 10:41 PM
Mazzenger's Avatar
Get either AFR 230's, Trickflow 235's or TSP 237 heads. All of those will get you 500+rwhp.
Old Dec 4, 2012 | 11:37 PM
transamfreak01's Avatar
Agree with what everyone says above. A blower set up for our cars with fuel and supporting mods in good shape is going to cost you your budget. I would build the 408 and if you want a little extra fun throw 100 shot in it. These motors will take it like a ****. My opinion
Old Dec 5, 2012 | 09:33 AM
A.R. Shale Targa's Avatar
Here's what I'd do with your budget seeing as you already have the cam....
http://www.texas-speed.com/p-588-tsp...ort-block.aspx
Then for your cylinder heads.....try these.............
http://texas-speed.com/p-3515-prc-as...ral-heads.aspx
This build would work well with your cam choice and still leave enough coin
for the T-chain set, oil pump, FAST intake/TB and a tune.........
Thanks for serving our country......
Old Jan 11, 2013 | 12:51 AM
Sinister_Z28's Avatar
When u get back from the desert give Thompon Motorsports a call they do alot of good budget builds. I just ordered all my stuff for my first 408 and it ran me 8700. Now i didnt go all out but i plan on improving it as i go. And i know what u mean cause my motor just took a **** through the side of the block.
Old Jan 11, 2013 | 03:51 PM
brians91formula's Avatar
408 LQ9 fully forged rated at 900rwhp with cam, New rockers, and PRC 237 heads can be had for around $8500 from Texas-Speed. This is a complete long block.
Thats what I would do if I were you. Obviously check into other sponsors to see if they could beat the price.
Old Jan 11, 2013 | 04:11 PM
Tainted's Avatar
Ill give this an update. I bought the PRC aftermarket LS3 heads, 260cc version. Hoping they ship soon!!
Old Jan 11, 2013 | 06:56 PM
garygnu's Avatar
check out the price of a Texas speed 408 long block with ls3 heads.talk to them about a good cam for ls3 heads.
Old Jan 11, 2013 | 06:58 PM
Tainted's Avatar
Id still recommend the aftermarket version for us smaller bore guys, just a heads up.
Old Mar 10, 2013 | 07:49 AM
RedEvilz28's Avatar
im running a 408 lq9 fully forged with a fast lsxr 102 and prc cnc ported ls3 heads i need help on what size converter to run an i dont know what power range ill be in from what i hear is like 490rwhp with the rite cam i havent picked out a cam yet ima call pat G and see what they say
Old Mar 10, 2013 | 09:29 AM
Tainted's Avatar
Yank ss3600
Old Mar 10, 2013 | 02:32 PM
RedEvilz28's Avatar
Why not 4000
Old Mar 10, 2013 | 02:55 PM
Tainted's Avatar
Depends on how much time you are on the street. Personally on a street car thats used often id ******* hate a 4000, 3600 would be my tops
Old Mar 10, 2013 | 07:07 PM
RedEvilz28's Avatar
It's going to be a weekend car
Old Mar 10, 2013 | 07:37 PM
Tainted's Avatar
Then a 4000 may not be so bad. Every converters "feel" is different brand to brand. My recommendation is find someone in your area and ask to go for a ride to see what a stall is like.
The 4000 will be killer at the track assuming nothing breaks. What I dont like about large converters for street cars is the slop and loosness in slow traffic, stop and go, and if you have a loud exhaust the rpms tend to 'hang' inbetween shifts and it can get annoying.
