Main studs and rod bolts
Technicaly, I would only do this if the engine was going to be pulled and all clearances properly checked. The rods should be checked with the fasteners that will be used. This is also true for the mains. New fastners should require that the block be aligned honed with torque plates again for the main journals and the rods should be checked for roundness and bearing clearances. Fastners put their own unique stress on the block and rods and this can change the clearances and geometry of the rotating assembly causing premature failure which is what you are trying to avoid in the first place.
On one stock shortblock that had ~3000 miles with ARP rod bolds we took it apart (for stroker) and the rod bearings look exactly the same as when the bolts were installed with no wear pattern at all, so I doubt there is any excessive stress caused by a better bolt being installed and pulling the big end out-of-round. Someday I'll verify that with a dial bore guage, although if its tweaked enough there is very little that can be done to fix it other than throw the rods away. Its recommended to do an align hone when doing main studs, but I've never seen an engine fail from stock main studs, I only install them in the customers engines that specify they want them.
