4.8 L Cam questions
Old Dec 17, 2012 | 10:09 PM
South Texas Krawlers's Avatar
Default 4.8 L Cam questions
First off, sorry if I am in the wrong area, not quite sure where to go for 4.8L LR4 stuff. I am getting ready to do an engine swap into my offroad only rock crawler. I need power off idle, but also up to 6000 rpm. I have found a custom ground cam fthat I thought about running. Specs are: 222/216 .566/.561 on a 113 LSA
I have a set of 5.3 cathedral port heads to install on the motor as well. What kind of power would I be looking at with this cam, or would it be a complete waste for me to use it?
Old Dec 17, 2012 | 10:49 PM
wildcamaro's Avatar
Looks like a good cam for stock heads and will have torque in the lower rpms where you want it... Make sure to throw some headers on it..
Old Dec 25, 2012 | 12:40 AM
Any other input from anyone?
Old Dec 25, 2012 | 08:42 AM
bww3588's Avatar
It's a reverse split cam. Generally reserved for engines with crappy intake and excellent exhaust systems. It should provide good low end power. I'm not sure how,it will act up top tho.
Old Dec 25, 2012 | 09:18 AM
garygnu's Avatar
look at comp 54-455-11,or check out camquest from comp cams.
