Forged Rod/Piston setup for 11:1?
Old Dec 22, 2012 | 11:26 AM
ckpitt55's Avatar
Default Forged Rod/Piston setup for 11:1?
Looking to build my motor to an 11:1 ratio with forged rods/pistons. Looking at using a 228R cam - this would put me around 8.5:1 DCR which is ideal since I am not installing an adjustable timing set (as of now) which limits my ability to advance/retard the cam to alter my DCR.
My problem is that I haven't had much luck finding a combination of parts that doesn't require me to mill the **** out of my heads to get the right static compression. Can anyone recommend a set of pistons/rods that will get me there with no or minimal modification to the 241 heads? I've been looking everywhere and haven't had much luck. Just looking to avoid additional machining costs if I can...
Thanks for your input.
