Does my timing gear set up look correct?
Old Dec 28, 2012 | 01:55 AM
Sommer86's Avatar
Default Does my timing gear set up look correct?
I'm re-building my SLP short block and just re-installed the used Rollmaster timing set that came with my motor, but the crank gear sprocket was already on.
Now, does the white mark on the crank sprocket (there is no dot) mean I should match that dot to the dot on the cam gear?
I need help quick, lol.
Old Dec 28, 2012 | 06:47 AM
wildcamaro's Avatar
Don't have that timing set but conventional wisdom would say if number one is at tdc then you good to go...
Old Dec 28, 2012 | 07:30 AM
Old Geezer's Avatar
With the "0" on the key, it looks as tho the original assembler used the white paint to ID the sprocket tooth that should align w/ the cam dot.
Old Dec 28, 2012 | 07:53 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Advance 2* on the left, Retard 2* on the right. You're right in the middle. I'd say you've got it!
Old Dec 28, 2012 | 09:06 AM
A.R. Shale Targa's Avatar
That avatar looks great, I mean the sig. pic is awesome, wait; what are we
lookin' @ again ?????? Uuuummmmmm timing marks...right; looks all good
Old Dec 28, 2012 | 09:08 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
It's perfect. Keyway will be about 2 o'clock when the dot is at 12 o'clock.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 30, 2012 | 09:03 AM
Sommer86's Avatar
Perfect!! Thanks fellas!
