info Lunati camshaft
Old Dec 30, 2012 | 11:18 AM
erix7's Avatar
Exclamation info Lunati camshaft
Hi
i just bought an Lunati cam shaft for my race car, this is the spec:
Valves lift .651 .651
lobe lift .383 .383
ADV dur 278 282
DU@.050 227 231
center line 108 116
I have the lunati pushrods and duble valves spring.
Ported 241 heads , stock valves , ls6 intake...
The block is all stock 2001 corvette LS1
What i want to know is if it will be ok with my stock piston ?
Thanks alots !!
Eric .W
PS : this is what i bought :
http://cgi.cafr.ebay.ca/ws/eBayISAPI...ht_3252wt_1105
Old Dec 30, 2012 | 11:21 AM
Rise of the Phoenix's Avatar
Are you talking about PTV clearance issues? You should be fine unless your heads are milled down to like 59cc or less.
Old Dec 30, 2012 | 11:31 AM
erix7's Avatar
yes PTV clearance issues !
Old Dec 30, 2012 | 12:15 PM
That is a relatively small cam, so you won't have PTV clearance issues. The MS3 and MS4 are much bigger cams and people run them with stock 241 heads all day long.
Old Dec 30, 2012 | 12:19 PM
erix7's Avatar
nice !!! thanks alots man !!!
Eric W
Old Dec 30, 2012 | 12:24 PM
You would actually benefit from having the heads milled some. It would raise your compression and give you more low end torque throughout the entire RPM range. A safe mill for that size cam would be between 60cc and 62cc.
Old Dec 30, 2012 | 01:15 PM
erix7's Avatar
Ok Thanks alots its help me alots !! What is The best Throtle body size you think with the ls6 intake ?
Old Dec 30, 2012 | 01:16 PM
wildcamaro's Avatar
I'd check it but usually companies make them so you don't have the ptv issues...
Old Dec 30, 2012 | 03:58 PM
I'd just use your stock one or have your stock one ported. No need to ugrade to a bigger TB unless you upgrade your intake.
Old Dec 30, 2012 | 10:16 PM
JakeFusion's Avatar
Super Hulk Smash
The heads are ported... was a valve job done and larger valves installed? That affects PtV more than milling does.
Old Jan 1, 2013 | 02:47 PM
erix7's Avatar
The valves are stock !
Is it really better for me to put à fast intake and TB (92/92?102/102?) or with the stock block and valves im ok with the ls6 intake ?
Im new in the LS world , i was running rotary engin before in my race car.
Thanks
Éric W
Old Jan 2, 2013 | 12:38 PM
Thanks
Éric W
If you've got the coin, then going with a FAST 102 and 92 or 102 TB would be an upgrade, but it really all depends on your goals. In my opinion, I'd just stick with your LS6 intake and possibly have your stock TB ported. The heads and cam are going to wake up your car a whole lot. If you end up wanting more, then upgrade your intake and TB, or just add nitrous. Adding nitrous will likely end up costing less than a new intake and TB.
I think going from a rotary engine to a heads/cam LS1 is going to surprise you.
