Water Pump
Old Jan 2, 2013 | 10:57 PM
ZL1Killa's Avatar
Default Water Pump
So my factory water pump is leaking from what I can tell around the shaft.
Guess time to replace. I looked around a little, at just a replacement factory pump, then saw Evans Cooling pump, Meziere electric, edelbrock.
What is everyone using or any recommendations?
I don't really care to go all out and go to an electric, as with all the necessary options to do that its $830. A factory pump replacement I think is $200. An Evans Cooling pump is $600 with all parts. I've heard good things about the Evans. Any input from people who are using it?
Old Jan 3, 2013 | 06:58 AM
LS1MCSS's Avatar
If it was cooling good with the stock pump before it started leaking, I see no need to replace it with anything else.
Old Jan 4, 2013 | 09:55 PM
gMAG's Avatar
I agree with this person ^^. If it worked correctly, it's good enough.
