lq4 gasket question
also whats the cheapest place you guys get your gaskets need head and manifold gaskets
thanks Justin
you can run 243 heads milled and still be clear of ptv with a mild cam under 600 lift with stock gasket.thats what im upgrading to next month and comp should be around 10.8:1 for a decent bump in power.
reach out to some vendors and discuss cam choices based on the plans for your heads for a package that will perform.
thanks
