Major oil leak!
I would definitely pull your intake, if anything you're pretty far along and what's another hour or two....
Good luck!
I sealed mine from day one so I haven't had an issue. It's no big deal really. Pull the intake and clean it thoroughly, and undo the valve covers and remove the rockers. Preload won't change. Clean up the bolts and the holes, apply the RTV (ultra black) or ARP sealant and retorque them all to 22 ftlbs.
Thanks for the help.
So Im gonna let it dry till saturday then take it for a rip and see if I can see any uv dye coming out anywhere.
Was there any oil on the bolts?
Where was the oil on the intake ports? Top of the runner, mid, bottom?
Head intake ports - light coating of oil, no oil sitting on valves
Intake ports on intake manifold, looking from bottom of intake - Black around around
Plugs- Caked with burned oil. Never seen this before in a 4 stroke.
Im wondering if its the valve cover gasket, I should know more tomorrow after a drive.
Would this caues it to come out the exhaust manifold? I still have to drive the car and see where its coming from but it appears to be exhaust manifold.
Sorry I don't mean to thread jack but this has something to do with a problem I've got.
Am I reading the above post correctly - you need to use loctite on the bolts for the rockers? I haven't seen this anywhere.
If this is correct, damn it I need to go back and redo this...
Yous sounds like an external leak of a different sort. Think OPSU or even rear main seal.
