ZR1 crank in a LQ4?
Old Jan 18, 2013 | 03:32 PM
BLACK-00-WS6's Avatar
Default ZR1 crank in a LQ4?
What all would have to be done to run a ZR1 crank in a LQ4 block? thanks
Old Jan 18, 2013 | 04:58 PM
KCS's Avatar
KCS
Moderator
It should go right in, but I don't think you can just bolt up a T56 or 4L60E. The ZR1 crank has a 9 bolt flange (LS1's are 6 bolt) and I think it's even thicker. Then there's the issue of gathering all the dry sump components since it has the longer snout.
