What is the casting Number on 5.3 Heads??
Old Apr 16, 2004 | 08:59 PM
Robs98SS's Avatar
Default What is the casting Number on 5.3 Heads??
What is the casting number on 5.3 Heads? just like the topic states.
Thanks
Rob
Old Apr 16, 2004 | 09:16 PM
DaleMX's Avatar
Compiled from older posts:
Here is a list of a few casting #'s:
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
More Info
Below is what I have. BTW, you stated that the 933 and 806 97-98 LS1 heads have a stock chamber volume of 69cc. I believe that is actually 66.67cc
__________________________________________________ __
Casting Number 806 or 933
LS1 (Perimeter Bolt)
97-98 5.7L Passenger Car and Corvette
Material: Aluminum
Casting Number 853 or 241
LS1 (Center Bolt)
99-00 5.7L Passenger Car and Corvette (853)
01+ 5.7L Passenger Car and Corvette (241)
Material: Aluminum
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
Casting Number 706
LM4 / LM7
99+ 5.3L Truck
Material: Aluminum
Casting Number 852
LR4
99+ 4.8L Truck
Material: Aluminum
Casting Number 317 or 035
LQ9
01+ 6.0L Truck
Material: Aluminum
