Torquer v3 what heads work the best
Old Jan 25, 2013 | 09:24 PM
hfthe3rd's Avatar
Default Torquer v3 what heads work the best
Hi guys, I know there's a million threads asking for info but what would you guys suggest is the best bang for my buck. I'm not looking for a high dollar head. I was looking at a used set but would rather buy new because I don't know if I'm buying junk or not .
My current set up is
98 trans am vert
Full bolt ons ( header , pulley , cut out , ported bbk intake , 80mm tb..)
3.73 gears with a yank 4k stall
Torquer v3 on 111lsa all valetrain upgraded
Ran best of a 11.9 so far.
I figure look at tsp heads to match the can but any other suggestions?
Also with a 98 what do I need to change for a head swap?
Old Jan 25, 2013 | 09:27 PM
gotjuice?'s Avatar
I have a set of AFR205 with under 1500 miles that worked GREAT with my Tv2 for $1600
Old Jan 25, 2013 | 11:46 PM
04goat350's Avatar
You have a pm
Old Jan 29, 2013 | 03:41 AM
hfthe3rd's Avatar
TTT for some weekday advice
Old Jan 29, 2013 | 10:23 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Give us a call. I'd really like the opportunity to discuss the car & goals with you. I think we can put together a head package that will work perfect for your car. We have aftermarket casting PRC heads & the ported stock castings in stock & ready to go. All we need to do is figure out what head suites your needs best & mill them up to meet your compression goals.
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
