Break-In for new heads?
Stage 2 LQ9 6.0L heads: (copy and pasted) Hot Tank and Pressure test heads, Fully Stage 2 Ported, Polished Combustion Chambers, UnShrouded Valves, 2.055 Ferrea Intake Valves, 1.60 Ferrea Exhaust Valves, bronze guides, Crane Dual LS1 Springs, Titanium Retainers for dual springs, Hardened spring seats, New Viton valve seals, New GM locks, 3 angle valve job
Along with a TR 224/227 .563/.569 114LSA
Now I have a D1SC Procharger going on at the same time, wondering what the breakin period is for a set of heads. I know the springs need to be heat cycled twice? Other then that, do the heads need to be run for a certain amount of miles? I just want to make sure everything is broken in properly before I put on the charger and slap it on the dyno
Thanks
I have been told it takes about 500 miles to break new cam, heads and valves, etc. cheers and good luck...............
