Cam Only Project(DYNO Numbers Added!!!)
Old Feb 5, 2013 | 09:38 PM
desertLS1's Avatar
No ported oil pump?
Old Feb 5, 2013 | 10:08 PM
trans_am7935's Avatar
Originally Posted by desertLS1
No ported oil pump?
was thinking the same thing, otherwise sounds good.
Old Feb 5, 2013 | 10:36 PM
455GTO's Avatar
No ported oil pump... 2002 TA's come stock with an ls6 pump and I only have 21k miles. Oil pressure is same as stock with the new cam. Didnt feel it was necessary for this build.
Old Feb 6, 2013 | 02:38 PM
Fred Flintstone's Avatar
thinking about useing this cam, cant wait to see the numbers.
Old Feb 6, 2013 | 08:24 PM
Zfireman28's Avatar
What cat back do you have with this set up?
Old Feb 7, 2013 | 11:47 AM
455GTO's Avatar
I have SLP LM2 and it is wayyyyy too loud! I bought the SLP power flo conversion in hopes to quiet the tone down... Having it installed on Saturday.
Old Feb 7, 2013 | 11:54 PM
455GTO's Avatar
Results are in!!!!!
First off let me say that the tuner is a friend, and has tuned roughly 6 cars and is by no means an expert. He has HP tuners and has the program down, but I'm sure a more knowledgeable tuner would not have run into the problems we did.
Idle was stuck between 17-22AFR... No mater what changes he made he could not get the idle down into the 15's... We weren't sure if this was due to the cam but it was quite frustrating. This was also the issue with part throttle, it was very lean around 20-25 until you stepped on it a bit... Maybe some one can chime in with why no fueling could be added... There was no knock present but it was just lean...
He made a few changes and we started doing WOT tuning and it went great! There were no fueling issues once we got into the WOT pulls. After 3 pulls we dialed in the AFR to about 12.6-12.8 throughout WOT.
The numbers far exceeded our expectations and I couldn't be happier with the tune and results.
The first graph compares the bolt on pulls to the cam pulls. Let me know what you guys think.
Attached Thumbnails Cam Only Project(DYNO Numbers Added!!!)-transamcam1.jpg   Cam Only Project(DYNO Numbers Added!!!)-transamcam2.jpg   Cam Only Project(DYNO Numbers Added!!!)-transamcam3.jpg
Old Feb 8, 2013 | 12:01 AM
parks450's Avatar
Impressive, those are pretty good numbers for mostly a cam.
Old Feb 8, 2013 | 06:17 AM
Jenson's Avatar
That is scary lean, tell your friend to read the sticky in the tuning section.
Old Feb 8, 2013 | 08:15 AM
wildcamaro's Avatar
Nice numbers for cam only...
Old Feb 8, 2013 | 10:14 AM
455GTO's Avatar
Thanks!
Does anyone have any ideas on the AFR at idle?
Old Feb 8, 2013 | 11:17 AM
  #32
BBATCAR's Avatar
Great numbers,,, makes me want to go from bolt-on to cam only...
Old Feb 8, 2013 | 11:26 AM
  #33
mchicia1's Avatar
What is scary lean about it? The lean AFR is probably him sitting at part throttle before he went WOT. It is below 13.0 the entire run at RPMS that matter.
Originally Posted by 455GTO
Thanks!
Do you have cats? Where was the wideband for the idle tuning?
Are trims turned on still? If so, what were the trims saying? If your PT was that lean, your trims would be maxed at 25%. Were they?
Old Feb 8, 2013 | 12:22 PM
  #34
455GTO's Avatar
No cats, and the wideband was in the tailpipe of the exhaust. We tried both tailpipes to see if that made a difference and both readings were the same.
I'm honestly not sure what the trims were at. He said once we moved to the PE table the trims worked themselves out and was great. We tried unplugging the MAF and still had the same lean idle/cruise problem. The faster we went on the dyno and the higher the gears it richened up... It was really only an issue at idle and gears 1-2... But no matter how much fuel he added at idle it would register almost in the 20'sAFR and cruise in 1-2nd gear.
Old Feb 8, 2013 | 01:38 PM
  #35
mchicia1's Avatar
At idle, the wideband reading is going to be skewed if it is in the tailpipe.
Also, that bold scares me a bit. Fuel trims are only used when out of PE and in closed loop, so of course in PE the trims are going to be 0%.
A cam in the 232/234 range is easy to tune at idle. Only use a wideband to tine idle and PT if you can put it higher up stream in a bung. He should have been using the fuel trims to dial it in.
