A new LQ4 block
Old Mar 7, 2003 | 11:19 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default A new LQ4 block
If one where to buy a new LQ4 block, would it need any prep work or can the internals be bolted in?
Old Mar 7, 2003 | 01:42 PM
LQ4somona's Avatar
Default Re: A new LQ4 block
Depends. If you are using a rotating assembly out a LQ4, just buy the new pistons, rings and bearings to assemble the engine. But if the rotating assembly is out of an LS1 you would still need to buy new pistons, but the rest of the assembly would need to be balanced for the engine to work descently.
Old Mar 7, 2003 | 02:05 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Is the question whether the block ready freddy? Always a good idea to check the bores but it should be okay.
