6.0L bottom end and machining
Case in point - I bought a motor with 38k miles on it thinking I'd simply be able to drop it in and turn the key. I didn't want any surprises, so I checked it out anyway. Turned out that rod, main, and cam bearings were all shot. Piston to bore clearances were excessive, and the crank had a casting defect on one of the main journals.
If I wanted a reliable 550 hp motor, I'd be taking everything apart to take measurements to see what I could re-use and what I could not. Re-ringing would depend on the condition of the cylinder bores - if there's no huge amount of o-o-R or thrust side taper then I'd probably do a clean up hone to knock of the glaze and throw new rings on to help my compression. New bearings are a no brainer given that they are relatively inexpensive to replace. At 550 hp, ARP hardware on all the critical components I'd say is a good idea. Rod bolts are good insurance - though I opted to put that associated machining cost towards aftermarket forged rods instead. I also installed main studs but ended up not needing a line hone. You'll need to check yours to be sure though.
Just my 0.02.
When I bought it, I merely installed a cam, ported heads, painted it and put it in the car. You can see the drag strip times in my signature.
I had to take my pistons/rods back because 1-3-5-7 were pressed on incorrectly.
Gen III rods all face the same direction, make note of it with plenty of pictures during dissasembly.
