Rebuilding a 5.3 LS1 specs
Besides, wouldn't that cause me some headache when I'm trying to smog?
Check out this LQ4: https://ls1tech.com/forums/western-c...picked-up.html
If you are just passing the visual and sniffer, nobody is going to tell whether you have a 6.0 vs. 5.3 so long as it passes smog and you retain all your emissions components.
If you want/need to be ref'd then you have to swap in the same year engine or newer from the same class of vehicle: passenger car(LSx) vs. light duty truck(4.8/5.3) vs heavy duty truck(6.0/6.2)
http://www.gmfullsize.com/forum/showthread.php?t=105536
