With all the adjustable rocker talk
Old Apr 19, 2004 | 10:48 PM
Beast96Z's Avatar
Default With all the adjustable rocker talk
How come no one uses the Comp Pro-Magnum series rockers? All the vendors sell these with guide plates for $459 bucks. Seems like a economical, adjustable, and rebuildable solution for many. There offered in 1.75 or 1.85 ratios. I don't think the 1.75 would increase valve lift enough to hurt anything unless you were very close on P/V to start with. I've used the Pro Mags in my LT-1, and they were great rockers. Anyone have any feed back as to why more people don't use these?
http://www.thunderracing.com/catalog...vid=3&pcid=108
Last set on the page.
Old Apr 20, 2004 | 05:24 PM
Beast96Z's Avatar
Guess no one knows anything about them?
Old Apr 20, 2004 | 05:41 PM
z-ya's Avatar
I do use them,some won't on account of the 1.75 or 1.85 ratio chioces instead of the 1.7 for the stock rockers.Also they are stud mounted with a rather small 8mm stud
instead of being shaft mounted.They have been used on some
big inch motors and I have not heard of any problems so far.If you pick your cam profile with these rocker ratios in mind I don't see why they would not work well.
Old Apr 21, 2004 | 12:09 PM
Deeavi's Avatar
I have them! They, Comp Cams, make a good piece! I have used the Pro Magnum roller rockers on several 400ci small blocks in the past. This is my first LS1, but I don't see any problem arising from the small stud as long as valve spring pressures are reasonable.
